SC Magneto
DRD
11-24-2004 21:51:08
Can anyone tell me if the two gears under the mag cap on my SC are timed. I need to replace the top gear (some teeth are missing). Are there marks on the two gears that I must line up in order for timing to be correct? Also how do I go about pulling top gear off?
Thanks for any help, DRD
David Davis
11-25-2004 07:22:08
 Re: SC Magneto in reply to DRD, 11-24-2004 21:51:08
The large one has 2 red dots and the small one dot, they are hard to see because of the rotor. Put 1 between the 2, this will time it. There is a screw on the bottom side of the large gear, back it out and the gear will pull off by hand. Have fun, Dave
Coloken
11-25-2004 08:46:29
 Re: SC Magneto in reply to David Davis, 11-25-2004 07:22:08
Like he says...two dots...or ....some times the corner of two teeth or one tooth on the other gear has been filed off. Just the corner is beveled a little. Maybe hard to see. The distributor contacts have to be lined up just as the points "OPEN".
