Need some modern part numbers
F-I-T
11-24-2004 19:30:25
Hello:
I have these part numbers from Paul F for the three fittings I need to order for the high pressure engine mounted hydraulic pump to the Eagle hitch. Can anyone with a newer parts book help me out? I hope these old numbers are correct?!?
VT5185 (To cylinder)
VT4920 to pump
VTA2861 Center connection
Thanks,
Frank
Joe (Wa)
11-24-2004 22:05:16
 Re: Need some modern part numbers in reply to F-I-T, 11-24-2004 19:30:25
Frank, I am not all together sure what you have now, or where Paul got those nrs.
The original installation is 2 pieces of �� steel tubing:
Tube nuts VT5183 (A30632).
Sleeves VT5182 (A30631)
1. Pump discharge: straight adapter 3/8� npt x �� tube VT4920 (A30597) + 1 ea nut & sleeve.
2. Center tube connector: �� tube union VT5187 (no cross-ref nr) + 2 ea nut & sleeve.
3. Control valve block: 45� elbow 3/8� npt x �� tube VT5186 (no cross-ref nr) + 1 ea nut & sleeve. The elbow is oriented so the tube enters the fitting from the transmission side under the step plate, the tube has to be bent to fit.
I doubt Case stocks any of these fittings. They are common medium pressure pipe/tube fittings�. hydraulic shop, McMaster-Carr, etc.
Joe
F-I-T
11-25-2004 11:03:04
 Re: Need some modern part numbers in reply to Joe (Wa), 11-24-2004 22:05:16
Thanks as always Joe! I went to McMaster and found all the fittings. I"ll try and think of some more to add on to this order, but will probably have it all collected by next weekend.
Thanks again!
Frank
