Case 400 diesel gages
Jeff Gregrow
11-24-2004 06:53:58
I need the 2 fuel filter gages for my 1955 Case 400 diesel. One is the vacuum gage that runs off the primary filter and mounts under the steering column. The other is the secondary filter gage located on the dash. Does anyone know of a supplier where I can get replacement gages that look reasonably original?
Don Rudolph
11-24-2004 11:16:54
 Re: Case 400 diesel gages in reply to Jeff Gregrow, 11-24-2004 06:53:58
John Saeli, who posts regularly on this Board has fuel pressure gauges. Fuel vacuum gauges are very hard to come by.
Pat T
11-24-2004 15:12:43
 Re: Case 400 diesel gages in reply to Don Rudolph, 11-24-2004 11:16:54
Darned near impossible, rather, to find the vacuum gauge. Saw a NOS pressure gauge go for over $80 on Epay a while back. Sure would be nice for someone to repro these things.
Jeff Gregrow
11-25-2004 10:15:46
 Re: Case 400 diesel gages in reply to Pat T, 11-24-2004 15:12:43
You aren't giving me much hope Don! I'm going to hit Goodrich's tomorrow and see if they have any parted out, maybe something sitting on a shelf. Otherwise, guess I'm out of luck, the vacuum gage is blackened.
Milky2390
11-26-2004 06:25:32
 Re: Case 400 diesel gages in reply to Jeff Gregrow, 11-25-2004 10:15:46
third party image
Take the gauge apart and see if it can be cleaned up. I painted both fuel gauges on My 600. The preasure gauge was black and the vac gauge was faded they both still work. Here are some pics from the parts and pieces gallery. They don't look perfect but ok if you don't look too close.
Link
http://www.tractorshed.com/cgi-bin/gallery/pieces_pic.cgi?pic=http;//www.tractorshed.com/gallery/pieces/v1914.jpg&firstrec=1&lastrec=15&Parameter=&mode=All&what=pieces
Jeff Gregrow
11-26-2004 10:24:36
 Re: Case 400 diesel gages in reply to Milky2390, 11-26-2004 06:25:32
How do you get them apart, they look sealed.
Milky2390
11-27-2004 07:23:06
 Re: Case 400 diesel gages in reply to Jeff Gregrow, 11-26-2004 10:24:36
Use a small screwdriver to pry open the back edge of the bezel or ring around the glass. Start at one place and work your way around gradualy opening until you can take the glass and then the face behind the needle off carefully. then when you put it back together I used a little silicone and crimped the bezel back together gently. You may be able to clean the preasure gauge off but if you use a solvent it may disolve the paint on the backround.
If it is unuseable now you have nothing to lose.
