Still searching for the Case 380 Front Fender Ligh
RF
11-23-2004 14:15:39
I'm still looking for a pair of front fender lamps for a Case 380 (David Brown 885).
These fit on the wide type fender and are 7.250" long, 5" deep x 3.250 tall. Case's old part numbers are 929167 and 929166. It appears that the new part numbers are 954472 (left side) and 954471 (right side). Any chance anyone may have one, a pair or a lead to where I may find a set? My local Case dealer doesn't have them and the tri-state (Ohio) sweep of Case dealers came up empty.
Below is a link to a picture I did of what lights I am referring to.
Thank you in advance for your efforts.
As a side bar, I have the 380 (885) diesel engine torn down and the previous owner had stripped the crank gear and timing gear of all their teeth. No other damage short of five bent pushrods. I just got the head back for a valve job. No cracks and it wasn't warped. I'm going to do a bore check this weekend. Ron
RF
11-30-2004 05:22:17
 Re: Still searching for the Case 380 Front Fender in reply to RF, 11-23-2004 14:15:39
Well thank you for the information. That's very helpful. I'll call my local dealer and see if they can get them. If not, do you have a source?
I was contacted by a David Brown dealer in England who offers a full set of lamps for the Case 380/David Brown 885. The lights are made by a company called Britax. They look close to the originals and he says they are better since the OEM had a bad habit of melting. Anyone know much about these lights?
I get mix reviews about this Case 380 tractor. When I mention David Brown, some tractor bigots I know go into a tirade of what a piece of junk it is; other swear it's a fine tractor, and with the Case name behind it, I won't hurt for parts (except for those goofy lights).
Reminds me of the debates with Chevy and Ford people in antique cars.
D Smoker
12-01-2004 16:26:56
 Re: Still searching for the Case 380 Front Fender in reply to RF, 11-30-2004 05:22:17
Have a set in stock, if you need them.
RF
12-11-2004 14:39:42
 Re: Still searching for the Case 380 Front Fender in reply to D Smoker, 12-01-2004 16:26:56
Do you still have these front fender lamps for the Case 380? It appears the ones I thought I were ordered were not. And they no longer show them in stock. :(
Drop me an email if you will please.
Regards, Ron
D Smoker
11-29-2004 17:26:36
These numbers substitute to 3123164R91 & 3123163R91. They are not direct replacements. Have a different lens and require you drill new holes, but they look close to the originals. Email me if you have questions. They are still available from Case.
RF
12-02-2004 11:22:02
 Re: Still searching for the Case 380 Front Fender in reply to D Smoker, 11-29-2004 17:26:36
Got em! Thanks for the information. Only Case can price these lamps this way. Right side $34.00, left side $40.00. I recall the Case dealer said they were for a Case 385. I see when I pick them up.
I almost purchased one from an old David Brown dealer in New York for $113. Glup! That was just for one!
Thanks again. -Ron-
