Need info on Case 310
rhedelius
11-23-2004 13:42:36
I am looking at purchasing a 50"s Case 300 series, model 310. It"s a gas engine and has a 3 point hook up, has been converted to alternator. Serial number is 6053591.
What year is it?
Where can I find a manual?
My father has looked at it and it fires right up. I"m new to tractors, but live on an acre and with a few attachments, this would work our great. Thanks!
Rick
Scott Flynn
11-24-2004 20:53:43
 Re: Need info on Case 310 in reply to rhedelius, 11-23-2004 13:42:36
A few things that I would add:
Although the 310/310B is lumped in with the rest of the 300/300B series tractors, it is what Case considered an industrial model. If a part was unique to the 310, a CaseIH dealer may get an invalid part number response when looking up a part. A Case construction equipment dealer may still be able to supply the part to you. Found this out when going to different dealers in my area.
Some dealers also get hung up on the fact that all tractors within the 300 series appear in the same parts catalog. I have had to explain this to the dealer on several occasions when a new person is at the parts counter (this is an old IH dealer).
Some parts for this tractor are pricey, but many are still available from the dealers. The parts/service/operator's manuals are still available from dealers at prices that are often below the reproduction prices found on websites (and often better quality).
We've had good luck with our tractor. It takes a beating and keeps on ticking. The heavy factory loader works great for hauling big bales of hay around on our farm. Other than being a little "cold blooded" in the winter, we get along great with it.
rhedelius
11-24-2004 09:12:28
Thanks for all the comments and suggestions. I haven't seen it in person yet, but it is a round nose for sure. The guy is asking $1000, which I think is a fair price. I have to come up with some attachments for it so I'll start looking. I'm kind of excited, these old tractors sure look like fun!
Rick
Coloken
11-24-2004 10:20:56
 Re: Need info on Case 310 in reply to rhedelius, 11-24-2004 09:12:28
Darn good price. I sure wouldn't sell mine for that.
Posible things to look for: Cracked exhaust manafold...they can be found. The little latches in the 3 point. They cost like you wouldn't believe. Of corse the condition of the tires..just figure that into price.
rhedelius
11-24-2004 10:26:55
 Re: Need info on Case 310 in reply to Coloken, 11-24-2004 10:20:56
Thanks for the info. I'll be sure to look at those items. The tires are pretty new (all 4), apparently it was used to cut weeds for a local scout camp. OSHA rules required a sturdy roll bar so they sold it to it's current owner. He bought it because he got a great deal on it, but it's really too big for his yard/needs.
Rick
Ray (WA)
11-24-2004 16:33:33
 Re: Need info on Case 310 in reply to rhedelius, 11-24-2004 10:26:55
I Bought a new Case "510B" Utility Gas model.
Had lots of trouble with carburator. Iwas to young at the time to put an inline filter on it.
It would pull with my John Deere "G" as long as you used three point equipment. A few years later Ibought a new "430" Case Diesel with loader It was one handy Tractor. I used it a lot. I always called the "310" the grasshpper Tractor because their Grill looked like a Grasshopper. My two cents worth, Ray
C. Amick
11-24-2004 07:30:14
I think manuals are still available from Case/IH. I got an I&T manual off Ebay for mine, but wouldn't recommend it, especially if you can find a Case manual.
Joe (Wa)
11-23-2004 21:22:36
Quite a coincidence, I just hauled a 310 home today, serial nr 6052768. Look on the serial nr page for Case model 300 & 320. The serial nr for 1956 has too many zeros (should be 7 digits), drop 2 zeros in the middle and we both have a 1956.
I don�t think the 310 has a separate manual. I have a 311B also with several 300 manuals and 300B-400B manuals. 310 & 310B are covered in those manuals, especially the parts manual, where it differs. The 310 is simply a model within the 300 series tractors.
Joe
Lincoln
11-23-2004 16:58:40
These are great little tractors. I havwn't had any problems with mine. Parts are a little hard to find at times. Just out of curiosity, how much is the asking price of the tractor?
Coloken
11-23-2004 15:48:08
You probably have what we refer to as the "round nose" later ones were 300B with diferent tin work. I have one. Has 4 speed trany and maybe a 2 or a 3 speed up ahead of it. Foot clutch stops both PTO and ground speed. Lever clutch stops ground speed so PTO keeps running. A great tractor, only thing I wish mine had power steering. I don't recomend one for a loader because of that. My 3 point has no problem with a heavy 6ft. Bush Hog.
Roger300
11-23-2004 15:24:09
Rick; The 310's were only made in '56 and '57 so it has to be one or the other, but you can click onto serial numbers along the side of this forum and check. Roger
