HELP 480C WON'T MOVE
Royboy
11-23-2004 12:54:31
I have a 480C that I use on my small acreage, so it sits alot between use. The other day I started it, let it warm up not long in Arizona when I moved the shuttle lever to the forward position nothing happened for several seconds then finally it moved forward. When I move the lever to reverse it backs up as it should, but pauses when placed in the forward position again. PLEASE HELP.
agri_con
11-26-2004 03:44:28
 Re: HELP 480C WON'T MOVE in reply to Royboy, 11-23-2004 12:54:31
Sounds like the forward piston spring in the power shuttle is broken (common prob).Remove the triangle shaped oil pan on shuttle and see what kind of debris is in the bottoem.
