case 380 won't stay running
Tbow
11-21-2004 20:06:06
I borrowed a neighbors Case 380. It acts like it is running out of diesel. I have cleaned the glass bowl before the fuel pump and checked the two canister filters which appear clean. I can keep it running by spraying starting fluid in the intake pipe but when it runs out of starting fluid it dies. On occassion I can keep it running long enough to drive it a block or so then it runs out of diesel again. (There is plenty of diesel in the tank) I would apprecitate any help !
Thanks, Terry
Dave Davis
11-25-2004 07:52:38
 Re: case 380 won't stay running in reply to Tbow, 11-21-2004 20:06:06
See if you are getting diesel to the primary filter, might be dirt or algea in the tank. Have trouble with an old dozer that sits around. Take the fuel cap off and blow air back from the filter. Dave
RickB
11-22-2004 14:20:53
There is no effective way to "check" the fuel filter elements. Invest the $10 in a pair of new filter elements and quit ethering the engine. I bought my DB885 for under a grand because the hired help ethered it to death.
