Hour Meter S C Case
Elliott from IL
11-21-2004 18:16:21
Can someone on here tell me how I can or if I can put a Hour Meter on my S. C. Case 1947. I want to pull Accurate Maintenance on the Rebiuld motor. It has a MAG on it. Thanks for your info. Elliott
C. Amick
11-23-2004 10:08:36
 Re: Hour Meter S C Case in reply to Elliott from ILL, 11-21-2004 18:16:21
Another option I thought of yesterday while driving home from work was to put an electic run time meter on it. I have one on a Kawasaki Mule (ATV) that works off the ignition switch. It runs when the ignition switch is on. If you are still running a 6 volt system, though, you may not be able to find one that will work.
CK Richard
11-22-2004 17:10:23
hour meter was an option on sc tractor (08178AB) it worked off of an oil pressure switch. A hot wire runs to one side of switch other wire from switch runs to meter. when tractor is running switch is made meter is running. hope this helps
Richard
C. Amick
11-22-2004 06:35:16
I don't know how to do it with a mag. You can do it if you find an old IH distributor that has a tach connection on it.
