430
las
11-20-2004 20:29:51
Gov springs on works well but throttle lever does not have enough friction to hold it wide open
Tom (Ks)
11-21-2004 09:17:32
 Re: 430 in reply to las, 11-20-2004 20:29:51
Check your throttle lever. There should be a friction disk right under the lever, then the shaft goes down inside the steering column where there are two jam nuts there to tighten the coil spring. You should be able to reach inside to feel the spring and nuts. 430's should be the same as 530's
