Oil leak?
Bunky (MI)
11-18-2004 15:18:29
I have Oil (gear lube) leaking out of the Brake housings on my Vac.. I assume the differential seals are bad are these hard to change?????
C. Amick
11-19-2004 12:29:56
 Re: Oil leak? in reply to Bunky (MI), 11-18-2004 15:18:29
A brake place should be able to re-line them for you. I get mine re-lined locally. Are they 6-inch discs?
Bunky (MI)
11-19-2004 12:33:56
 Re: Oil leak? in reply to C. Amick, 11-19-2004 12:29:56
I think they are 6 inch disc Do you remember what it cost roughly???
C. Amick
11-19-2004 13:42:34
 Re: Oil leak? in reply to Bunky (MI), 11-19-2004 12:33:56
It was $50.00 for two.
Bunky (MI)
11-18-2004 18:04:35
so do you have to pull the bearings and housings or can you just change the seal????
Also does anyone know if the brake linings are still available???
Paul f
11-19-2004 10:18:44
 Re: Oil leak? in reply to Bunky (MI), 11-18-2004 18:04:35
Don't know if discs are still avaialble...just degreased mine and they work OK. Any truck brake place should be able to replace teh lining material. To me it was easier to remove the bearing carrier Only teh cup comes out the bearing stays on the shaft. It is too hard for me to pull a seal with a shaft sticking out of it. Also I could use my press to get the new seal in without distorting it
Paul f
11-18-2004 15:34:33
Do you have band or disc brakes?
Just did one side on mine (disc)...Make sure you drain off the rear end fluid...somewhat of a mess when I pulled off the bearing/seal carrier.
Was not a difficult job...make sure you check the plug in the end of teh shaft (looks a little like a freeze plug)... mine was the real source of the leak not the oil seal.. plug is still available from case...have of new part # somewhere if you need it
Paul f
