Timing a 580 CK.. How?
JZ
11-17-2004 10:33:14
I have a 70's 580 CK that needs its timing set. The main problem being that once I have removed the cover to access the timing marks I can see the pin, but the fluid sloshing around prevents me from seeing the timing marks when using a timing light.
Do you have to drain the transmission to set the timing? I am worried that doing that may damage the hydraulic clutch.
Help!!!
