VAC starter switch ?
Robert Paris
11-17-2004 08:00:09
Could the starter switch be the cause of slow cranking of the engine. The switch is very stiff and sometimes I believe there is bad contact. If I press very hard on the switch the starter seems to respond ok, if I release somewhat the pressure the starter does'nt respond as well or stops. Is it normal for the switch to be stiff like that ?
C. Amick
11-18-2004 13:07:38
 Re: VAC starter switch ? in reply to Robert Paris, 11-17-2004 08:00:09
I assume you are running on a 6 volt system. Are your cables at least size No. 2? Do you have a crank to turn the engine over with to check to see how hard it is to turn? The clutch disc could be not completely released and dragging against the flywheel.
Arthur
11-18-2004 03:55:33
Also one of the first things you should check and clean are the battery, and starter conections....corosion there will lead you to believe your battery is not charged , slow cranking ect. Most people don't check the starter conection. good enough. You need to take it off and hit it w/ sand paper,or steel wool, and a wire brush. Good luck
Robert Paris
11-18-2004 02:38:44
Thanks guys for your response. I guess I'll jump wire the switch first to see what's going on and I'll end up cleaning and lubricating the switch after all.
mj
11-17-2004 17:41:04
Take the switch apart, lube the moving parts and clean the copper contact surfaces. It should work fine upon re-assembly.
F-I-T
11-17-2004 09:16:33
Robert:
If you suspect the starter switch might be the cause of slow cranking, you could jumper acorss it, maybe with the ignition switch off, and see if it cranks better. It's a cheap try....
Frank
