sc clutch adjustment problems
kirkwannemacher
11-17-2004 03:51:53
Ok, I read many past post on this topic. I want to adjust my clutch on my sc. You have to put constant pressure on it to make it fully engage. I had the inspection plate off several times and can not find the pin that every one talks about. Is this pin on the levers that move forward and back or is it the part that spins. Please give as much detail as possible. Thanks
C. Amick
11-17-2004 10:58:47
 Re: sc clutch adjustment problems in reply to kirkwannemacher, 11-17-2004 03:51:53
It's on the part that spins. You will have to rotate the clutch assembly around until it comes in view. It's on the outside edge of the clutch assembly and faces the rear of the tractor. It's a round spring loaded button about 1/2" in diameter and sticks out 1/4" or so. Work from the access port on the left side of the tractor. Remember to spray some lubricant on it before you depress it.
