Rakin' Leaves, Weldin' Stanchions, Fixen' Snowblow
Glenn FitzGeral
11-16-2004 15:38:36
As you may have noticed I haven't posted lately. I've just been too busy getting ready for winter to work on my restoration projects. The only time I've posted lately is to weigh in on the "How many plows can my tractor pull?" question. Pretty soon I'll be back on the SC. I have the cylinders honed up, rings/gaskets on the shop bench, and just need to get at it. Near as I can tell the off center problem with my AWF is in the drag link. Either it is very worn on the gas tank end or some parts are missing. The 'ball' of the ball and socket joint is about one inch too far forward. The whole system is off restulting in too short of turns to the left and not short enough to the right. The threads of the drag link are too damaged to take the link apart. I have the drag link and arm that came with the AWF. It appears to be in good shape. Looks like I'll simply put that one on. Can't wait to get back at it. I knew when I took the tractor apart I should've waited but I REALLY wanted to know what shape the engine was in. And while the engine was apart I replaced several seals and o-rings on other areas of the tractor. Should be much better when I get it back together. It's good to know I still know how to ramble on! This is still my FAVORITE tractor site! Thanks for bein' there. Glenn F.
Don Rudolph
11-16-2004 17:16:08
 Re: Rakin' Leaves, Weldin' Stanchions, Fixen' Snow in reply to Glenn FitzGerald, 11-16-2004 15:38:36
Glenn,
I am afraid that we'll soon be getting hit in the butt by snowballs. At my ripe old age I am beginning to dread winter. It just makes life harder. And this year it is going to cost some green stuff to keep from freezing to death. We also are too busy preparing for the onslaught to do much tractor work, but it is always just around the corner. Always good to hear from you. Don
