VAC Eagle Hitch pressure relief setting
JerryW
11-16-2004 05:42:46
Does anyone know what the relief setting for the VAC Eagle Hitch setting is. My book says that the hydraulic system is 800 to 900 psi but does not state whether this is for the Eagle Hitch or the belt pulley system.
Thanks Jerry
mj
11-16-2004 18:57:33
 Re: VAC Eagle Hitch pressure relief setting in reply to JerryW, 11-16-2004 05:42:46
The early Eagle hitch depth control valves had the pressure relief set at 800-850 psi while the later ones were set to release at 900-1000psi. On early valves Case recommended using one or more plain 5/8" washers placed in the pressure relief plug behind the pressure relief spring until the valve released at the later spec. The belt pulley high-pressure system valves were set to release at 1900-2000 psi.
Joe (Wa)
11-16-2004 13:38:57
Relief valve 800-900 psi is for the Low pressure system valve in the hitch control block.
Joe
dctom
11-16-2004 06:48:16
eagle hitch with live pump belt pully system was 4200# dctom
