S Case with spring mounted wide front
dkasey
11-15-2004 22:24:31
Could someone take a look at ebay #3853420884 and tell me what type of front end is on it? Never have seen a spring mounted front axle. Looks like a factory install. Serial # has SC, not S. Good looking S Case though. Thanks for any information. Chuck
Tom Railsback
11-16-2004 17:37:27
 Re: S Case with spring mounted wide front in reply to dkasey, 11-15-2004 22:24:31
Correct me if I'm wrong, but didn't all SI's have a flat grille? At least, I've nenver seen even a picture of one with the regular S grille.
JerryW
11-16-2004 12:33:56
Years ago I saw a Case LAI with a frontend that I remember to be real similiar to this one.
Jerry
Don Rudolph
11-16-2004 12:30:45
It looks like an SI front end mounted on an SC.
caseman-d
11-16-2004 11:25:06
Front end doesn't look original. You be the judge!
caseman-d
Third Party Image
Bill from wisc
11-20-2004 06:16:26
 Re: S Case with spring mounted wide front in reply to caseman-d, 11-16-2004 11:25:06
The spring front end is from a SI. I owe a SI that was sold to the military and it has the spring wide front axle and round front grill. I am guessing who owned this tractor wanted a wide front end and found this one and put it on.
Grapefarmer
11-19-2004 08:28:53
It looks like a HOT ROD! I kinda like it!
JICASECOLL
11-18-2004 19:52:35
The military used CASE S's in World War II. Many of them were parashuted into combat sites for the construction of air fields. The spring setup helped reduce front end damage when they had a rough landing.
dkasy
11-16-2004 13:45:03
Thanks to all for looking and the opinions. So it is a SI front suspension from your responses.
Have never seen a SI with this front end. We had a 42SC new and I don't remember it being that polished, but that was a lot years ago. And I put many hours behind the wheel. Again thanks, Chuck
dctom
11-16-2004 13:14:28
someone put togeather a SC-4 with a DI spring axle and home made bolster, nice job but not original
C. Amick
11-16-2004 11:47:21
Looks like it came out from under a Ford Model A?
dctom
11-16-2004 05:56:57
some industrials had spring mounted front axles
caseman-d
11-16-2004 19:36:33
 Re: S Case with spring mounted wide front in reply to dctom, 11-16-2004 05:56:57
Tom,
Can you tell us anything from the serial number. It is 5221138.
caseman-d
