DC Eagle Hitch Springs
Bruce Nelson
11-15-2004 19:09:19
third party image
My DC project is coming along well and is actually nearer the end than this picture shows. Does anyone have a flat style Eagle Hitch latch spring that I can look at to try to duplicate? Maybe some real good pictures with dimensions? Was that exact spring used anywhere else, on an 830 or another tractor? Also, I need some VC1419 hairpins that secure the lift arm pins. I assume that these also fit a V series tractor. Does anyone know where these are used other than my DC? Where else might they be found?? I know I can use hardware store stuff just fine, but that just wouldn't be CASE like. Thanks for any help. Bruce
Joe (Wa)
11-17-2004 17:34:46
 Re: DC Eagle Hitch Springs in reply to Bruce Nelson, 11-15-2004 19:09:19
Bruce, The VC1419 pin was used on the VA series high pressure hitch but not the low pressure eagle hitch. The cross-ref nr is A29714, Don't know if still avail from Case.
The 300 & 400 series used the flat latch spring O9228AB, cross-ref A27670 still avail from Case. Don't know if it will work on DC.
Joe
