Koler K301A Crank
NOZLMN13
11-15-2004 00:42:10
I have a 1975 Case 222 with a Koler K301A. The crank in the engine is oval. Can anyone give me any information on getting a new one or getting mine fixed? Engine mod. K301A Ser. 7057581 Spec. 47529d Tractor mod 222-75
Bruce Nelson
11-15-2004 17:02:42
 Re: Koler K301A Crank in reply to NOZLMN13, 11-15-2004 00:42:10
Take your Kohler crankshaft to a crankshaft grinding shop and have them grind it .010" undersize. An auto machine shop can either do it or know where to send you. Then, buy a .010" undersize connecting rod from any Kohler parts supplier. The .010" rods are identified with a 3/16" hole drilled through the beam, about 1" from the big end. Of course, if you already have a crankshaft that is .010" undersize, there is no fixing it as Kohler only makes a connrcting rod in Std. and .010" undersize. So, grind the crank and get the right rod and it's as good as new.
