580CK Bucket won't lift
Chuck Johnson
11-14-2004 22:14:53
I have a very old 580CK that the lift just died. The bucket tilt and backhoe still work fine. If I tilt the bucket it will stay up (a little). Sometimes it won't go down even when I push the lever forward. Other times, it goes down when I tell it to go up. I can tell it is trying to lift, and if I throttle up all the way, I can get it partway up with the bucket empty. This happen abruptly yesterday. I think it's the control valve. Does anyone have any recommendations? This backhoe is ancient, and it isn't even mine, I borrowed it from a friend. I'd like to return it in working condition without spending a fortune.
Roger (Mi)
11-17-2004 21:00:05
 Re: 580CK Bucket won't lift in reply to Chuck Johnson, 11-14-2004 22:14:53
If the other cylinders work fine, but the loader doesn't lift, a piston packing has blown in one of the lift cylinders. If you totally unscrew the cylinder gland nut on one side, start the motor, and feather the lift valve, and a gush of oil comes out, that's the one with the blown packing. If a gush of oil doesn't come out, it's the other lift cylinder with the blown packing. Good luck.
