case 530 id
RK Rick
11-14-2004 06:24:44
I have what i am told is a 530, it has a 31 loader and backhoe.no id on tractor.2 speed shuttle, standard cluch. i am wondering if they made a 530 with king pin front, what other tractors had a 31 loader/backhoe?
George S in the real NY
11-26-2004 04:42:17
 Re: case 530 id in reply to RK Rick, 11-14-2004 06:24:44
The 530 CK version has/had the ID plate on the right side of the instrument panel, about in line with the seam or chrome tirm on the fuel tank. Look for two small holes about 2 1/2 in apart. I got a 32 loader and the tag is on the left near the step to get on the tractor. The tag for the hoe is on the stand for the hyd control valves. Mine was built in '65, so yours is probably eariler than that. If the tag is gone off the tractor, the number is forever unknown. The weight given in another post has to be for the bare Ag tractor. The CK with loader and hoe is over 10,000#. Not something you can haul behind a pickup. I have not been there in a long time, but you might prowel thru the archives at this site as many of the questions you will have have been discussed before. I have found the dealer to have a lot of parts still in stock for this tractor. Manuals for these are available from Case. Have fun with it. George S.
chvet73
11-14-2004 16:35:05
I used to have a 530 with 31 loader and hoe. Didn"t have the serial plate either. Most of the 31"s were on 530"s. Good machine, enjoy it.
ken gale
11-15-2004 19:21:53
 Re: case 530 id in reply to chvet73, 11-14-2004 16:35:05
can anyone give me an estmate of the wieght of a case 530?
yak651
11-16-2004 13:07:57
 Re: case 530 id in reply to ken gale, 11-15-2004 19:21:53
I recently purchased a '67 case 530, said the weight was approximately 3700 lbs in the manual
