VAC Tire sizes???
Bunky (MI)
11-12-2004 13:33:27
My 1945 Vac has 11.2-28 tires on the rear and it has 5.60 tires on the Front it sits pretty high in the front is this right or should it have 34's or 38's on the rear???
jGeoMo
11-15-2004 05:24:59
 Re: VAC Tire sizes??? in reply to Bunky (MI), 11-12-2004 13:33:27
I have 13.6 on mine. Makes it set better. Still need to add weight to reduce slippage.
wheat Straw
11-13-2004 18:29:13
Bunky,
5.50 15 on the front. If you measure the heigth of the rear axil with the 28 or the 34 your are going to have the same clearance or more under the axil of the 28 inch rears. If you have the two sizes to compare, look at the depth of the tire. The taller rims have tires that are thinner or shorter. It's a brain teaser but i think you will see this to be true.
Have a good one
Wheat Straw
Bunky (MI)
11-13-2004 18:36:15
 Re: VAC Tire sizes??? in reply to wheat Straw, 11-13-2004 18:29:13
I understand...
JerryW
11-12-2004 15:46:06
11.2 x 28 tires are real common on a VAC. SOme did come with 34 however. They seem to like to sit up in front a little.
Jerry
