SC Battery ground Neg. or Pos.
Bob in Texas
11-11-2004 19:41:48
Should a 1949 SC be positive or negative ground? Mine is positive grounded and starter turns over ok. Single wire alternator is not wired and is labled negative ground. What happen if leads are swapped?
Paul f
11-12-2004 05:42:13
 Re: SC Battery ground Neg. or Pos. in reply to Bob in Texas, 11-11-2004 19:41:48
Starter motor doesn't care about +/- ground. I assume you have a magneto...if so switch your battery terminals before you hook up the alternator...it will care (at least the internal regulator will) about +/- grounding.
Paul f
11-12-2004 05:45:11
 Re:Forgot to add in reply to Paul f, 11-12-2004 05:42:13
you will also have to reverse the wires on your ammeter or it will show backwards...I believe
caseman-d
11-11-2004 19:51:59
Negitive ground
caseman-d
