Case 730 Comfort King
Dan Travis
11-11-2004 15:09:22
What is one to do when there is gasoline in your crankcase? Where is it leaking from. How to fix it? Thanks
les payne
11-27-2004 22:17:12
 Re: Case 930 Comfort King in reply to Dan Travis, 11-11-2004 15:09:22
Hello
Can someone please help us. we are looking for some fuel rubbers for our case 930 comfort king tractor. We need fuel line rubbers for 3/8' tube and 1/4' tubes. having great difficulty locating them. If anyone can help would be greatly appreciated.
Thanks les
Doug Franks
11-11-2004 15:58:57
 Re: Case 730 Comfort King in reply to Dan Travis, 11-11-2004 15:09:22
This happened to me once. The float in the carburator stuck . This allowed the fuel to fill up the intake manifold , up to the heads and drained down the oil ports into the crankcase. I rebuilt the carb ,with a new float and hav'nt had any more problems.
Dan Travis
11-11-2004 16:06:29
 To: Doug in reply to Doug Franks, 11-11-2004 15:58:57
This will help it run smoother,without backfiring?
Doug Franks
11-12-2004 17:16:12
 Re: in reply to Dan Travis, 11-11-2004 16:06:29
Backfireing sounds more like an electical problem, like timming or points. The way I found my carb trouble was to take the breather tube off at the carb and set a small soup can at the carb opening and see if any fuel come out of the carb overnight. Im sure there are a lot of better and more technical ways to do this check, but this is my , "low cost, farmer, shade tree machanic " method. LOL!!!. Doug
NP
11-12-2004 17:56:58
 Re: in reply to Doug Franks, 11-12-2004 17:16:12
Well, it seems that some "backfiring" could be caused by a sticking float.
As best I recall, some "backfiring" occurs when unburnt fuel is ignited in the exhaust pipe, which could be caused by a rich condition.
