case 580D hydraulic Hoses
Mick
11-11-2004 00:10:11
Hi all
Just got my first backhoe - a 580D
I need to replace some hoses.
Some appear to way to long.
Is there a list of all the hoses and their specs for this loader.
Also what are the fitting specs
Thanks
Mick
agri_con
11-13-2004 04:07:53
 Re: case 580D hydraulic Hoses in reply to Mick, 11-11-2004 00:10:11
Most C.D.& E's use a #14 JIC female fitting at the valve body of the hoe-ending up with a male of the same size at the other.If it takes a 1 1/4 wrench it's a #14,if your working on a hose at the bachoe control valve,save yourselve alot of aggrivation get a 1 1/4 crow foot wrench.
Dennis/Ohio
11-13-2004 02:03:54
Hi, If you find a parts manual for your hoe. It should have the hose and fitting info at back of the manual. My model #31 manual tells the length of each hose and the fitting part numbers. But its all Case numbers, not alot of info that would help at a hydraulics shop. I have my hoses made at a local rubber dealer. Half the price of hoses at the local hydraulic shops.
Try the crawler/backhoe forum too. Best wishes, Dennis....
Mick
11-16-2004 21:13:27
 Re: case 580D hydraulic Hoses in reply to Dennis/Ohio, 11-13-2004 02:03:54
Where is this crawler/backhoe forum you mention.
TIA
Mick
Dennis/Ohio
11-17-2004 02:30:52
 Re: case 580D hydraulic Hoses in reply to Mick, 11-16-2004 21:13:27
Crawler forum is here on YT site, left side of page or at the top when you first sign on to Case forum.
