Thanks to those who have responded. Ontario must be DB country - got a couple of good notes from there. One guy has a under-slung elbow, so I might consider re-routing the exhaust. However, without a muffler stack, I won't have any warning when I'm looking back and about to be scraped off the tractor by a limb. Guess I'll just have to be alert for a change. The gauges don't work, but I'm not sure if it is the gauge or the wiring. The owner had to wiggle a wire to get it to start, so I know they need some attention. The local Case IH parts guy said the hydraulic parts (valves & pump) are getting hard to come by. Are there any good internet sites for parts? I still need a source for manuals. I wasn't aware of the 2-stage clutch (although I think I understand it)and don't know what some of the knobs & levers operate (differential lock?). I did find a note in the archives on how to install a delco alternator if the generator goes south. I want to pressure wash it. Is there anything I should avoid other than the air filter, breather caps, electrical components? Hopefully the grease, fuel, and dirt are not the only things holding it together. Thanks again and still write. JB in Texas.
