VAC Sheet metal
Paul f
11-10-2004 07:45:40
The parts manual show two Braces mounting to the top front corner of the side panels.
One is listed as VT3863 the other VT3632. One connectst from the right side sheet metal to the last stud on holding the valve cover (Maybe the 3863). My tractor only has that brace.
It looks easy enough to fabricate but I don't know what it connects to and the VACs at teh junk yard are to far gone to provide a clue.
Question how does the second brace (to the left side panel) mount?
mj
11-10-2004 08:48:03
 Re: VAC Sheet metal in reply to Paul f, 11-10-2004 07:45:40
On tractors with lights at the junction of the side panels and hood there are 2 holes in the light bracket that bolt to the side panel mounting holes. On tractors with lights at a different location there is a flat bar ( 1 1/4 x 3/16") that runs from the brace mounting hole on the right panel to the left one.
Paul f
11-10-2004 15:39:16
 Thanks in reply to mj, 11-10-2004 08:48:03
Thank you Fabrication can begin
Paul f
