Case 400 diesel
markloff
11-09-2004 20:14:07
What weight of oil should I use in the winter in a Case 400 diesel. Also do the decompression valves help in cold weather starting? Mine is disconnected. Where can I find a good service manual? Thanks in advance, Mark
Scott KY
11-10-2004 17:04:18
 Re: Case 400 diesel in reply to markloff, 11-09-2004 20:14:07
My 400 has a block heater on it. That would be your best bet for starting in cold weather. The decompressor is only used to turn the engine over to set the valve clearance. I am a firm believer in using only 30 weight oil in the older model tractors. But that's just my opinion.
John Saeli
11-11-2004 03:50:07
 Re: Case 400 diesel in reply to Scott KY, 11-10-2004 17:04:18
Hey Scott: Do you use 30 in the Winter? Here, in N.Y. we get down to 0 F. The benefit of Multi-grade, such as 15W40 is that on start-up, it has the ability of a 15W to get circulated quickly. Believe it or not, most engine wear occurs on start-up. Then, when the engine is warm, the 15W40 has the lubrication quality of a SAE40.
Scott KY
11-11-2004 17:43:56
 Re: Case 400 diesel in reply to John Saeli, 11-11-2004 03:50:07
I use Case IH number 1 30 weight oil all year. Thats what was recommended by the manufacturers. Of course that was before multi grade oils where manufactured. I have had good luck with the 30 weight oil so I will stick with it. I remember the owners manual for a 2090 Case I owned said not run multi grade oil or engine damage could occur. That was good enough for me.
John Saeli
11-11-2004 18:05:03
 Re: Case 400 diesel in reply to Scott KY, 11-11-2004 17:43:56
Hey Scott: My 2094 manual says the same thing, just looked. But every tractor I own gets 15W40. Never had an oil related problem. Only engine problem I had in 16 years was a pitted sleeve on the 870. She got a complete rebuild cause she deserved it.
John Saeli
11-10-2004 03:37:38
Hey Markloff: Make sure that the oil you use has the rating for Diesel Service. I never thought the de-compressor helped in cold weather. It sounds good in theory, but actually I think it's worthless. Must be a reason why they aren't in use. A diesel needs heat & a de-compressor takes heat away. For cold weather I recommond a block heater. Also 2 Group 31 Batteries, 1,000AMP @ 0 degrees F. hooked in parallal. Heavy guage battery cables. I like 2/0. Not to be confused with 2 guage. Do not use Ether!!
caseman-d
11-09-2004 20:15:56
10-30 muti-grade would be a good choice for gas or diesel.
caseman-d
