885david brown hydraulics
wallytx
11-09-2004 19:18:04
I have a 885 that has erratic hydraulics.It lifts loads ok but starts jerking if I pull lever too far back.Lowering implements has to be done very carefully because implements drop like a rock.Rate control won"t do anything.Implements drop about 3 inches while raised then move back to correct height every few seconds.Control valve was worked on by case dealer because one of the valves was frozen.
need your help, wallytx
jimtx
11-11-2004 05:47:37
 Re: 885david brown hydraulics in reply to wallytx , 11-09-2004 19:18:04
any time you make an adustmeent be sure 1 @ a time. no shot gun approach
Elmer
11-10-2004 16:05:18
You may need to reseal the lift cylinder piston.
