Identify Case tractot
tccharr
11-09-2004 16:58:03
I just got a case tractor from my Uncle that past away. How can I find out make and model. The best info I can find out it is a 1942 case. Came from Florida most likley it was used in the orange groves.
Don Rudolph
11-09-2004 20:54:21
 Re: Identify Case tractot in reply to tccharr, 11-09-2004 16:58:03
If you can find the serial number DC Tom, who monitors this board, may be able to tell you the build card information. Otherwise just the serial number will tell you the model year. It probably is an orchard model-possibly a DO.
John H-WI
11-09-2004 18:21:54
If you think it is a 1942 it will be either a V, S, D, or L series. If you look on the dash there should be a plate with the serial number (7 digits) plus the model number, If its a S, D, or L the serial number and model should be on the block on the flange where it connects to the transmission housing. You might also do a search on the tractor photos on the left here . Do a search on Case. It may also be an orchard version.
terryh
12-12-2004 15:22:19
 Re: Identify Case tractot in reply to John H-WI, 11-09-2004 18:21:54
These are the numbers I found on the flange that connects to the transmission. 5309364 So ex
