adding weight
c p
11-09-2004 14:30:33
I have a case 530 CK with a three point hitch. I am looking to build a weight rack. I was looking for some info on how much it should weigh and tips on building one. I figure it should weigh around 1000 lbs. Is this to much not enough? Thanks
BKahler
11-09-2004 19:22:40
 Re: adding weight in reply to c p, 11-09-2004 14:30:33
If you're going to be using the tractor with a front end loader then the 530 CK manual suggests 1400 lbs of weight. For other uses they suggest 900 lbs.
Brad
