Vac runs erratic???
Bunky (MI)
11-09-2004 13:33:08
My Vac runs erratic it sometimes runs like a top and other times it won't idle and acts like it's too rich.. I have so far changed the points rotor and wires, rebuilt the carb and cleaned out the Gaslines.. and adjusted the tappets.. anyone have any suggestions????? ?
Bunky (MI)
11-10-2004 03:18:41
 Re: Vac runs erratic??? in reply to Bunky (MI), 11-09-2004 13:33:08
Well I'm gonna change the manifold gasket this weekend and see what happens ...
Is there a Trick to setting the float on the MS???
OH and Tom keep looking it should be there LOL
C. Amick
11-10-2004 06:53:10
 Re: Vac runs erratic??? in reply to Bunky (MI), 11-10-2004 03:18:41
You should be able to tell if the manifold gasket is leaking around the intakes by spraying a flamable fluid around the gasket area with the tractor running. If it's leaking the RPM's of the engine should change. You checked the push rods to make sure they weren't bent didn't you? Did you replace the condenser when you replaced the points? I once bought a new condenser that was bad. The tractor spit and sputtered at idle.
Bunky (MI)
11-10-2004 07:02:57
 Re: Vac runs erratic??? in reply to C. Amick, 11-10-2004 06:53:10
Well I haven"t checked the push rods yet but this weekend when I put on the new valve cover gasket I will... Is bent pushrods a problem with the VAC??? checking the pushrods was mentioned before..
C. Amick
11-10-2004 08:06:56
 Re: Vac runs erratic??? in reply to Bunky (MI), 11-10-2004 07:02:57
I think I was the one that mentioned it before. No, bent push rods is not a common problem with the VAC. I have a Case 300 that had the oil filter stem missing like you did and as a result the head wasn't oiling properly. I also had a bunch of bent push rods. I don't know whether the lack of lubrication for the rocker arms could have caused the push rods to bend or not?
Eric Foster
11-09-2004 17:50:56
Does it run rough at an idle and also at higher rpm's? I had a similar problem, but only at higher rpm's. I hosed the carb out twice and it cleared up. The second time I concentrated on the "equalizing" ports on the inside surface of the throat.
I've also seen a lot of guys on this site talk about the float adjustment on the MS carbs.
JerryW
11-09-2004 15:23:25
Classic symptoms of a vacuum leak.
Jerry
C. Amick
11-09-2004 14:14:51
Sounds like the needle valve could be sticking. Next time it happens tap on the side of the carb when it is running to see if it makes any diference. Did you put any kind of filter in the fuel line to keep dirt from coming from the fuel tank?
Bunky (MI)
11-09-2004 14:24:46
 Re: Vac runs erratic??? in reply to C. Amick, 11-09-2004 14:14:51
Yes theres a filter in the fuel line It probably could use new one.. I question the needle and seat. but it has a new one...
dctom
11-09-2004 14:58:32
 Re: Vac runs erratic??? in reply to Bunky (MI), 11-09-2004 14:24:46
do you have problems starting it at times? i had a vac one time that ran like you say yours dose and i found the key in timing gear on cam half sheared off, would run fine one time and like crap the next, just a thought tom
todd hamilton
11-09-2004 16:56:30
 Re: Vac runs erratic??? in reply to dctom, 11-09-2004 14:58:32
Hey Tom - I can't find the vacuum line on my SC!:^)
dctom
11-10-2004 02:35:52
 Re: Vac runs erratic??? in reply to todd hamilton, 11-09-2004 16:56:30
maybe some one stole it i understand it is a hot item
