Timing for 1816C w/ Onan engine
Howlingowl
11-08-2004 15:16:10
Hello...my 1816c with an Onan engine is running poorly..new plugs, new points/condenser, plug wires measure good, new coil. The gas supply is good but when I run it at full throtle it is weak and misses quite a bit. I need to choke it part way to keep it running. I"ve adjusted the point gap and played with the carb jet screw but its not gotten better.
I suspect the timing but don"t know how to adjust that....any suggestions? (1200 hours on it)
Thanks!
Klyde
11-09-2004 16:25:32
 Re: Timing for 1816C w/ Onan engine in reply to Howlingowl, 11-08-2004 15:16:10
Point adjustment is the timing adjustment on an onan. Degrees BTC for your engine is stamped on engine block by points box, Remove air hose between shroud and air cleaner to locate flywheel mark and marks on cam gear cover. Belive your engine is 21 degrees connect timing light to #1 (closest to flywheel) and adjust with allen screw on points. simple as I can make it.
