VAC HP HELPERS
CT
11-08-2004 15:12:42
is there any other head cam or? that will help other than the normal oversize kit for more power for pulling.
mike's600
11-10-2004 16:57:50
 Re: VAC HP HELPERS in reply to CT, 11-08-2004 15:12:42
I used a 148 out of a 311b, cut the head 125 thou, and turned the rpms.I won alot with the the tractor. I still had a hard time with some super C's over 4.5 mile per hour. I would find a 188/201 gas and put it in the Vac. It takes some mods, but should give you good returns.
C. Amick
11-10-2004 07:08:21
Some people put the guts out of a 148 cu.in. engine in the VAC block. Have you done that?
Arthur
11-10-2004 03:48:06
The best way to increase hp on a VAC for pulling purposes, is to jack up the radiator cap, pull your VAC out from under it, and drive a DC, or an LA under it....Problem solved. JMHO.... Arthur
Klyde
11-10-2004 09:49:40
 Re: VAC HP HELPERS in reply to Arthur, 11-10-2004 03:48:06
Radiator cap from a VAC won't fit a DC or an LA!!!
CT
11-10-2004 04:52:08
THERS OTHERS AROUND THAT DO WELL AND IJUST WANTED TO BE COMPETIVE. IF YOU CAN GET A DC OR LA IN 2500 LPS I WILL PULL IT!
