VAC Adj. Widefront Question
Way Up Here
11-06-2004 04:20:46
There is a VAC adjustable (cast iron front axle) widefront not too far away from here that is for sale. The guy says that these are quite hard to find and I'll admit I've never seen one up here in person before. It has the original and complete Eagle Hitch on the back with factory hydraulics, etc. Tin is all there but it needs work while the rear tires are only fair. Tractor runs and the hydraulics work but the engine and clutch are somewhat tired and probably need rebuilding. Are these things worth very much more than a standard widefront VA or a regular narrow front VAC?
JerryW
11-06-2004 06:09:11
 Re: VAC Adj. Widefront Question in reply to Way Up Here, 11-06-2004 04:20:46
Around me a VAC tractor with a good wide front and Eagle Hitch would bring at least $500 more than those without.
Jerry
