more 730 questions
INCase
11-05-2004 05:14:51
As some of you may remember I've been battling with a stuck 730 for some time now. I have a question for the experts out there. Is it possible that the "live" PTO and/or Hyd system is holding the engine as well? What is a good way to tell/check for that? (I can turn the PTO with a Pipe wrench) Thanks!
jon f mn
11-06-2004 16:40:10
 Re: more 730 questions in reply to INCase, 11-05-2004 05:14:51
when i was a kid we had a dc that the live power shaft siezed on. we had to split the tractor to find the problem. of course this was after dissasembling the engine first.
John Grimm
11-05-2004 07:06:11
I don't a thing about a 730 in particular, but I doubt anything hydraulic would keep the engine from turning. My DC sat over 30 years and was stuck. I took of the valve cover, pushed down on each rocker arm to free up each valve while spraying liquid wrench onto each valve and guide.
I then heated up some auto trans fluid to near boiling using a soup can and propane torch and poured some into each cylinder. I did this in cold winter weather by the way. After I left it sit a couple weeks, i removed the starter and spark plugs. I worked a flat ended pry bar against the flywheel teeth and with a lot of patience I had the engine freed up in about 30 minutes. That was several years ago and I have not run into any problems yet.By the way, once it was freed up I spun it over with a battery (with the plugs still out) and let the ATF shoot out. That is one barn wall that will never rust !
