Case 300 gears
caser-up
11-04-2004 16:48:38
The transmission gears when I shift in my Case 300 grind when I try to shift from reverse to 1st gear and vice versa. When I push in the clutch I have to sit there about 10 seconds till the gears slow down enough to let it go in gear. Can this be fixed ? does it have syncronizers or what is causing this?
C. Amick
11-05-2004 09:48:13
 Re: Case 300 gears in reply to caser-up, 11-04-2004 16:48:38
It is not a syncronized transmission. Slowing the engine down is the only advice I have. I assume that you are not running any equipment with the PTO when this happens?
