more 1570 questions
zoidberg
11-04-2004 12:28:12
Hello !
We just bought a 1570 and the operators manual has brought up some questions.
The first concerns the engine oil. The manuals states that you must not use multi viscosity oil. Why is that? We use 15-40 C-IH oil in all of our IH tactors and would like to just have one common oil.
Also , the manual says the when pulling a load the tranmission should be in the second powershift. Is this just to allow for both an up and down shift, or is another reason?
Thanks for your responses.
zoidberg
just Roy
11-04-2004 15:09:56
 Re: more 1570 questions in reply to zoidberg, 11-04-2004 12:28:12
At the time the 504 engine was intoduced Multable viscosity oil had its problems anlong eith the fact that if run to long it will break down quicker than streight wieght oil. I have seen many tractors run with multi wt. oils wiith no problems if it is changed before it breaks down As for pulling in 2nd powershift the only reason would be so you had 1 up and 1 down, I always liked to use 3rd as it is direct drive 1 to 1 ratio. Neither will hurt the transmission.
