clutch
kirkwannemacher
11-04-2004 06:17:53
Need detailed info on adjusting my clutch on the sc. It works but when in 3rd and 4th gear I have to hold it all the way forward. Does it just need adjusted or is something else wrong. I read about a snap it is supposed to do. I don"t notice this snap. Maybe just a little bit. Thanks
C. Amick
11-04-2004 09:38:48
 Re: clutch in reply to kirkwannemacher, 11-04-2004 06:17:53
Remove the inspection plate on the left side of the tractor. Rotate the clutch plate assembly until a you see a small button that is about 1/2 inch in diameter along the outer edge. Depressing this spring loaded button allows the adjuster plate to spin independent of the rest of the assembly. Spray this button with some lubricating oil before you depress it so that it doesn't stick in the down position. With the button depressed, spin the plate one notch at a time and see what effect it has on your clutch. I think in your case, you need to spin it clockwise, but I don't remember for sure.
dctom
11-04-2004 06:25:51
just needs adjusting push pin in aqnd rotate one notch at a time till it really snaps in tom
JOE HINES
11-06-2004 22:42:10
 Re: sr # 5411801 in reply to dctom, 11-04-2004 06:25:51
CAN YOU TELL ME ANYTHING ABOUT 1950 SC sr# 5411801, IT WAS PURCHASED NEW BY MY GRANDFATHER. TRYING TO RESTORE IT.
