VA Case Tractor Wiring
Jamie
08-22-1999 14:45:40
I just bought this CASE VA narrow front end tractor, it is a 1949, or so I believe. It has been converted to a 12volt system. I was wondering if there is a way to step down the voltage to six volts for the starter. 12 volts is just to much and I am breaking off bolts when trying to start it. I am not holding the start button very long. Also, the battery is not charging, can someone tell me where the wires should run too. I am going to take the alternator in and have it checked( it is an AC DELCO). Please send to my e-mail. Thank you
Jamie
Jerrie Lot
08-22-1999 20:17:01
 Re: VA Case Tractor Wiring in reply to Jamie, 08-22-1999 14:45:40
I would think your starter must be out of alignment or something. I have had twelve volts on my VAC for about 7 years now and never have had a problem with the starter. As for the wiring on the alternator I don't know I have a 12 volt generator off of my 1030 on it. I think you have to have some kind of exciter on it because an alternator is AC current instead of DC current like a generator so it will not send electricity out until it has electrcity going to it. I think from the field to the ignition switch if I remember right. Better check with someone else to make sure so you don't burn the alternator up.
