930-1030 heads
Ed Service
11-03-2004 08:06:18
Will 930 heads fit onto a 1030 engine and would this improve commpression ratio? My goal is to improve starting on the 1030 even at a cost of some power. Thanks Ed
jon f mn
11-04-2004 02:27:23
 Re: 930-1030 heads in reply to Ed Service, 11-03-2004 08:06:18
i dont want to seem pushy, but 1030 heads are not the same as 830 heads. check the casting numbers. the manifolds will not fit.
Thad
11-04-2004 16:03:31
 Re: 930-1030 heads in reply to jon f mn, 11-04-2004 02:27:23
Comfort King heads are the same weather its a 930 and 730 or 830 1030. The early engines had diff casting #s and had the cut out for the decompressor. Thats the diff in #s.
CK Richard
11-03-2004 17:00:53
930 and 730 heads the same 1030 and 830 heads the same.
Thad
11-03-2004 16:42:08
Yes they will fit. I have put 730 or 930 heads on a 830. Worked fine we used the 730 manifolds. One of the engines uses a taller cyl head i cant remember which is taller. So you need to make sure the head bolts are ok. I think they are the same but something to check. As far as starting starts better power wise cant tell much diff. Hope this helps Thad.
jon f mn
11-03-2004 11:06:16
no. 1030 heads have larger valves, intake and exhaust ports so the manifolds wont fit.
