Vac Governor Spring??
Bunky (MI)
11-02-2004 16:50:01
Does anyone know if the spring that goes on the shaft where the hand and foot throttle hook together is still available if not what others have done to make this work..
JerryW
11-02-2004 19:58:00
 Re: Vac Governor Spring?? in reply to Bunky (MI), 11-02-2004 16:50:01
I just ordered one from my Case dealer. Was about $10.00.
Jerry
F-I-T
11-02-2004 19:59:57
 Re: Vac Governor Spring?? in reply to JerryW, 11-02-2004 19:58:00
Jerry:
What was the part number? I might get one to install if I ever have to take mine apart.
Frank
JerryW
11-03-2004 20:08:10
 Re: Vac Governor Spring?? in reply to F-I-T, 11-02-2004 19:59:57
Frank
The number for the governor spring is A30572.
Jerry
Bunky (MI)
11-03-2004 04:59:44
F-I-T do you have a photo of the old style governor linkage (distributor side) I think mine is bent or something...
F-I-T
11-03-2004 14:34:24
 Re: Vac Governor Spring?? in reply to Bunky (MI), 11-03-2004 04:59:44
third party image
Bunky:
The only picture I have is not all that well defined. The linkage just runs straight forward as a rod and terminiates with the spring at the front. If you need more, I can take some pictures this weekend.
Frank
F-I-T...large picture
11-02-2004 19:27:50
third party image
This the way I rigged mine with a small bracket and a spring from the rack at Home Depot.
Frank
