difference between DC's
Nick in Kansas
11-01-2004 16:20:31
Ok, I have been around both DC's and SC's all of my life. Think I was driving a SC with a hand clutch, by the time I was 4. Now I hear there are DC 3 DC 4 and all sorts of other things out here. All I ever knew them by was a DC or SC. Can someone please explain what all they are?
Scott Green
11-02-2004 13:42:56
 Re: difference between DC's in reply to Nick in Kansas, 11-01-2004 16:20:31
The way I understand it is: (1.) DC - Fixed front and rear , (2.) DC4 - Fixed front axle / ajustable rear , (3.) Then there is what they call a DC4 with ajustable front axle , (4.) DC3 is ajustable rears with tricycle / single front
Camboted
11-01-2004 21:24:43
Nick, you are not crazy, All the DC's with the exception of the orchard and high clearance "Cane" version were interchangeable. Our family bought several new DC's during the 40's & 50's, we always bought both the front ends, and switched from DC-3 to DC-4 every year for tillage and back for cultivation, about a 45 minute job, when things were not rusty and you had experience.
dctom
11-01-2004 17:19:21
DC-3 is a cultivating tractor, duel wheels narrow, single wheel and adjustable axle, DC-4 has adjustable rear axle but solid front wide axle, SC's were the same dctom
Glenn F.
11-01-2004 17:18:51
SC3 and DC3 also came in adjustable wide front configurations. The AWF option still rendered them a row crop. Glenn F.
Brian in Ohio
11-01-2004 17:02:46
A DC3 was the standard row crop DC with a narrow front end. A DC4 had a wide front end.
Gene dotson
11-01-2004 19:47:23
 Re: difference between DC's in reply to Brian in Ohio, 11-01-2004 17:02:46
The DC-4 was the short wheelbase of the DC series. The fixed tread front axle was mounted directly below the radiator. ALL DC-3"s had the front wheels mounted in front of the tractor for the long wheelbase. Could have 1 wheel, 2 wheel narrow or adjustable wide front. The DC-4 looks like a D with adjustable rear axles and 38 inch rear tires... Gene
Nick in Kansas
11-01-2004 17:20:28
Ok, so I have had both wide front ends now. Was my adjustable front one a DC4?
Nick in Kansas
11-01-2004 17:25:17
 Re: difference between DC's in reply to Nick in Kansas, 11-01-2004 17:20:28
Guess I should have read the rest of your posts!! thanks guys for all the info... Nick
