Why does the Case owners manual say always to run
Tom in Mo.
10-31-2004 15:43:46
I have a Case 830 LP CK and have read the operators manual for the tractor front to back. It says to run the engine at full throttle ALWAYS. Many times in many chapters it says to start engine and run full throttle no matter whether it is working or sitting still. It says this 7 or 8 times or more. It even says in the winter to warm up a cold engine at full throttle. Anyone know why the factory wouldn't want their engines to idle low like any other tractor? Does this maybe have to do with the 5 inch stroke against a 4-1/4 inch bore?
Roger (Mi)
11-01-2004 04:57:19
 Re: Why does the Case owners manual say always to in reply to Tom in Mo., 10-31-2004 15:43:46
Times have changed, and so have the properties of motor oils. Additives and multi-viscosties have greatly improved the ability to lubricate and remain stable at different temperatures. Do not run a motor at full throttle when it's cold. The greatest friction and wear occurs when it's cold. My father-in-law (now deceased) would start his brand new Wheel Horse lawn tractor and immediately set it at full-throttle. It lasted three years before it sent the connecting rod through the side of the block. Rather, it would have been better to set it at half-throttle and use it without a heavy load until it fully warms up.
wwminc
10-31-2004 18:44:20
My 611B series book says to run at full throttle only under very cold conditions. At normal temps run at 1/3 to 1/2 throttle until warm. The worst thing you can do is run an engine slow at cold temps. The parts simply just never warm up causing increased wear due to "cold" oil and other reasons.At normal temps,[I"ll say 50 above] reduced throttle will still maintain temp in the engine. Got to remember a engine dislikes the cold, and/or cold running. I suppose Case realized this and put in in the book. I know for a fact that when I cover up the grill to restrict air flow in the dead of winter pushing snow, the tractor runs much better, temp gauge in the middle. Andy W
