611B filter for COM full of stuff - is this normal
Kirk in Oregon
10-31-2004 06:22:10
Hi Guys! Still playing around with this 611B that followed me home. Cleaned the filter to the case-o-matic system the other day. Found some fine metal shavings, bits of what might be clutch facing material (?), and something like white paper with red writing on it (?!?) inside the filter. Is this normal, or is disaster brewing? Previous owner(s) were not kind to this tractor; may be decades of accumulation. Any words of wisdom for me? -- Kirk
Lincoln
11-02-2004 06:37:53
 Re: 611B filter for COM full of stuff - is this no in reply to Kirk in Oregon, 10-31-2004 06:22:10
When I first got my 611B home the filter had not been changed in 20 some years. I was pretty gunky, but I don't recall any metal shavings. If the previous owners were always grinding the gears, which is common with a COM, it may be from that. I would change the filters, use it for a while, then check to see if the problem persists before you get too worried. Did you change both hydraulic filters?
dufrain
03-25-2005 23:21:50
 Re: 611B filter for COM full of stuff - is this no in reply to Lincoln, 11-02-2004 06:37:53
Hey Guys I know this is an old thread but I wonder if you can tell me where the filters are on the 611b.Im sure they need cleaned or changed.thanx
