Case 1570 Squeal
lcoulter
10-30-2004 22:08:26
I purchased a case 1570 at an auction recently. It has a high pitched squeal at higher rpms when it is in gear (not in neutral). I also used it with a land level and it would squeal when it called for hydrolics. I haven"t been able to locate the exact location of the noise yet, but I was wondering if this is a common problem when the hydrolic pump is going our or if anyone had heard of this before. Also someone had added a third hydrolic valve and I didn"t know if this might be what is causing the problem. Thank you for the feedback.
D.
10-31-2004 12:29:15
 Re: Case 1570 Squeal in reply to lcoulter, 10-30-2004 22:08:26
I would guesss that it has something to do with the third valve, unless it has the optional pump and valve on the left side of the transmission housing. Sounds like the relief valve may be bypassing.
