hydraulic help needed
Nick in Kansas
10-30-2004 16:07:38
I am slowly getting my DC4 back to working order, but I am having problems figuring out the hydraulic system. Years ago, we were pulling a peice of equipment that had 2 single action cylinders on it. Grandpa rerouted the hoses so that the cylinders worked faster. On the right side of the tractor, I have the hose coming off of the lower valve going to, if I remeber right, the filter housing. I am sure that isn't right, but the filter housing looks like it should have a hose going to it. On the left side, I have the hose off of the lower left valve going to, what looks like a half inch pipe hole in the reservoir. and I KNOW that isn't right. Any help or info is helpful! Thanks Nick!
PS... this is a '53 with live power, and an eagle hitch
Paul f
10-30-2004 18:36:02
 Re: hydraulic help needed in reply to Nick in Kansas, 10-30-2004 16:07:38
Nick: Sounds you have a dual valve pump. The lift cylinder for the hitch uses one pair (upper)the remotes the other (lower). The upper left feeds the lift cylinder (and should have an over sized elbow...the down speed control unit). The upper right feeds directly to the filter body. Eagle hitches didn't have down pressure. When the lever is moved to the down position theh weight of the hitch pushes the fluid back though the upper left hose..the big elbow has a spring lodes control that slows the return thus slowing the drop of the unit.. simultaneously the pump output flows through the upper right outlet to the filter and back into the reservoir. The remotes use the lower two outputs
