Clutch on a 580B
old
10-29-2004 20:47:31
How much or how little do you need to remove to put a clutch in a 580B backhoe. Have one here that needs one badly. When you puch the pedel down it doesn't release. Was not fun to unload from the trailor, had to jam it in gear and hold on and hope. Believe that the preasure plate is bad and maybe the throw out bearing
Roger (Mi)
11-01-2004 05:37:19
 Re: Clutch on a 580B in reply to old, 10-29-2004 20:47:31
I'm assuming you have the manual shuttle with a disk clutch. Remove the front grill, disconnect the hoses on the side-frame reservoirs, remove the side-frame reservoir nipples, remove the side-frame bolts (4 bolts)(after blocking the side-frames up), disconnect the battery cable, remove the hood, throttle linkage, fuel lines, etc. Remove the starter, block up the torque tube, and remove the torque tube bolts. Put a wood block between the oil pan and a floor jack, jack it up, and roll the motor forward. Another mechanic and I could change the clutch (with parts on hand) in 580's in less than two hours.
old
11-01-2004 07:38:05
 Re: Clutch on a 580B in reply to Roger (Mi), 11-01-2004 05:37:19
To bad your not in Missour we aren't looking foward to do this job
