Case Model 40
Rob Lord
10-29-2004 18:35:09
Hi I have an old Case tractor it is a modle 40 with a seiral # 8068554, 4 cyl diesel. The engin is in poor condition ( not sure what size or who makes the engin. it has a 4.020 bore ) could you let me know what kind and size this motor is , also if there are any used engins available. Thanks Rob
Dale In Tx.
10-30-2004 17:07:24
 Re: Case Model 40 in reply to Rob Lord, 10-29-2004 18:35:09
Hey, Rob! Never heard of A case 40!!! Maby 400?? look on left side of engine flange rear next to air cleaner I have model "400" LPG 8081539,built in Oct 26 1955, your's should have had 4" pistons when it was new, the 1957 "super diesels" had 41/8 pistons, and A (700-800)block. IT is A case engine 251 cubic in. original 4x5 hope this helps. Dale In Tx.
Tom Railsback
10-30-2004 19:17:55
 Re: Case Model 40 in reply to Dale In Tx., 10-30-2004 17:07:24
Rob: There was a CASE 40; it was built from 1912 to 1918 and then renumbered the 20-40. I'm sure that's not what you have. Like Dale said, you likely have a 400.
