Just did that
RickB
10-29-2004 15:06:05
I just bought a 1976 Case 885 (DB) with poor compression from ether abuse. Installed pistons, rings, wrist pins, rod bearings. Rebuilt the water pump, replaced the starter and gave it a full service. All CaseIH parts (except starter) and filters and NH fluids. Total parts $725 USD. I am happy with a nice little 42HP diesel tractor with live hyd and PTO, power steering and three point hitch. It had broken rings and ring lands, but the bores were very good at 2800 hours.
RF
10-29-2004 16:03:46
 Re: Just did that in reply to RickB, 10-29-2004 15:06:05
Thanks for the reply.
Where I am perplexed is what to offer at this auction. It's a sealed bid affair. I look at the machine, then fill in the form and turn it in with my top bid.
May I ask what your tractor cost before you put the $725 into it? If I just have to sink seven or eight hundred into it (plus what ever I bid), I'm game!
Any idea what a running Case 380/DB-885 goes for on the open market running?
RickB
10-30-2004 04:08:12
 Re: Just did that in reply to RF, 10-29-2004 16:03:46
I wouldn't offer more than what you suggest. 'Engine noise' may well indicate crankshaft damage which involves much more labor and parts cost than I just incurred. I had the luxury of getting my tractor started and evaluating it prior to making an offer, as well as some prior knowledge of it. I can't imagine a big rush to place bids on the Case; low ball it, and if you don't get it, you may be the lucky one.
eddie in Ky
10-29-2004 19:23:30
I have an 885 with loader that I just turned down $4500 for. It isnt pretty but its a good tractor.
