loader on VA?/live pump
Ross
10-29-2004 15:05:42
Anybody have any luck putting a loader on a VA? I've got a freeman loader from a case utility (300 I was told but I think it's too wide. Also I've got a live pump from a later VA I want to put on. Was the timing gear beefed up when they started running the hydraulic pump off of it?
Thanks in advance
Ross
Joe (Wa)
10-29-2004 17:05:42
 Re: loader on VA?/live pump in reply to Ross, 10-29-2004 15:05:42
The cam gear was changed tractor serial nr 5365686 (some time in 1949).
The drive gear on the pump was changed from 7/8" wide to 1-1/16" wide engine serial nr A4700000.
Far as I can figure out that is 1949 also ���
Joe
Ross
10-29-2004 17:43:29
 Re: loader on VA?/live pump in reply to Joe (Wa), 10-29-2004 17:05:42
Okay, Do you know where I can find the engine serial number? The tag on the column is gone. The only number I can find on the block is behind and above the oil filter and reads VAB12060. By looking in my I&T manual I can tell I have the govenor that has two mounting holes so I guess I'm stuck with the older style engine. I don't suppose it makes a difference that I have a mag does it?
Thanks again for your help
Ross
JerryW
10-29-2004 16:35:56
I believe the gear was beefed up quite early in the production of the Eagle Hitch. Possibly still in 1949 and I do not know but maybe they beefed if up again later.
Jerry
